| Ogłoszenie |
| JEDNA SPRAWA = JEDEN TEMAT |
| Błąd Ogólny |
Could not obtain poster group information.
DEBUG MODE
SQL Error : 1064 You have an error in your SQL syntax; check the manual that corresponds to your MariaDB server version for the right syntax to use near '2858,13187,2858,13187,,2176,10928 )
AND ug.group_id IN ( 2631 )
AND g.g...' at line 3
SELECT ug.user_id, ug.group_id
FROM (phpbb_user_group ug, phpbb_groups g)
WHERE ug.user_id IN ( ,2858,13187,2858,13187,,2176,10928 )
AND g.group_id = ug.group_id
AND g.group_single_user = 0
AND ug.user_pending <> 1
ORDER by g.group_order DESC
Line : 991 File : viewtopic.php
Jeśli nie potrafisz znaleźć rozwiązania tego problemu, możesz spróbować poszukać, lub zadać pytanie na forum: http://www.przemo.org/phpBB2/ |
