2008-11-28, 00:57
THE FIRST IMAGES OF THE NEW MCV..!!!!
Ger Nijkamp
Silnik: 1.6 MPI 16v
Wysłany: 2008-05-09, 22:40   THE FIRST IMAGES OF THE NEW MCV..!!!!
The prediction that was made a couple of days ago was accurate:
See all first real pictures of the renewed Dacia logan MCV here:
www.dacialoganmcv.nl
[ Ger ]
Wysłany: 2008-05-10, 00:10
Not so much to get used to, to be frank - changes aren't big, after all. However more paint-covered bumpers are less practical...
Much more interesting thing is: what about equipment?
Ger Nijkamp
Silnik: 1.6 MPI 16v
Wysłany: 2008-05-10, 18:13
Well, based on the pics it's obvious there will be a 'Prestige'-version, just like with the Sedan. I assume the technical specifications will stay unchanged: after all it's a re-design not a totall make-over. Maybe a dustfilter for the dCi motorized versions.
[ Ger ]
Wysłany: 2008-05-10, 23:35
Of course I thought about such elements as safety belt pretensioners and similar - improving ergonomy or easy to include in new versions without too much work.
(Probably every forum about Logan had threads similar to our "top 3 annoying things" or "equipment you dream of").
But from my, mostly practical, point of view, "Prestige" is totally disinteresting - just even more paint in stupid places <; The same about leather: "no, thank you"...
Ger Nijkamp
Silnik: 1.6 MPI 16v
Wysłany: 2008-05-14, 09:44
I agree, 'Prestige' is only adding some design elements and nothing really functional. At this stage there is nothing known about other (technical) changes or improvements.
[ Ger ]
Sweeper
Model: Scenic
Silnik: 1.9dCi
Wysłany: 2008-05-20, 15:13
more photos:
Renault Scenic 1.9dCi
Galeria Renault 5: www.renault5.pl
PIKUR: www.klubrenault.pl
